Kona Steve
Member
- Joined
- Aug 16, 2020
- Messages
- 7
I was given a Rode K2 by a friend who was dismantling his studio. I brought it home and got a really nice take on a project track. (Recording through a Mackie Onyx into Logic.) Then, the mic made a dreadful screeching noise and went quiet except for a low hum, which persisted even with the power supply turned off but still plugged in. Before continuing, let me make clear that I am definitely not an electric tech guy. So, please bear that in mind.
The hum sounded like ground loop, but on flipping the lift switch (with the unit back on) it just got louder, so in reading about it I figured it was the more than 10 year old tube dying.
I replaced it with generous and thorough advice from Christian Whitmore. The tube is a Amperex/Phillips PCC88/7DJ8
I followed directions carefully on tube replacement and then the Rode manual for sequence of hookup. I had headphones on and as soon as I plugged the power supply box into the outlet I heard a significant hum, without even turning on the unit. I flipped the ground/earth switch again, but that made it worse. On turning the unit on, I got a pretty loud, deeper hum that diminished in maybe 30 seconds, which I guess was the tube settling in? The initial higher pitched hiss/hum remained, and that was all that came through to Logic.
I tried switching XLR cables, power outlet, cleaning contacts, checking that the tube was seated, but the sound remained and nothing was being picked up by the mic.
I read that the mic power should be plugged into the same house circuit as other parts of the chain. Tried that, no change. I switched power cords, tubes, nothing. I checked tightness of connections and found that the seven pin plug into the power supply had a fair amount of wiggle. With it switched on, I had that steady low hum/hiss, and when I wiggled the plug, I got loud cracking like when you plug in a guitar to an amp. So, I bought new 7 pin cable which definitely was a more snug fit in the power supply and eliminated those noises on moving the cable. However, there was still a hum as well as some electric cracking, along with the initial short-lived, loud, deep hum that happens every time I turn it on. I tried swapping tubes back to the new one and that periodic cracking stopped. However, still no analog signal from the mic. I tried a different house circuit and a different power cord. Nothing. Still just plugging in the power supply with it off, I could hear hum in my headphones, worse when turned on. So, that leaves something within the mic or something within the power supply?
I live on the Big Island of Hawaii, so finding a tech to test the components is tricky and mailing them expensive.
What did I miss? Recommendations?
Many thanks for wading through this long description and any ideas you might have to help resolve this issue.
Steve
Steve
