CJ
if you are on a battleship and bombs and machine gun shells are going off, you do not care too much about s/n ratios and frequency response,
so a lot of reduced figures are for military products and have nothing to do with their actual response unless they are marked for 20 to 20Kc,
so there are a lot of good buys out there if you know what the actual response is,
now when you put DC on an inductor, that funny curve you see on the above graph i posted turns into a straight line so you can not see much difference between it and the same coil around a core stacked differently
here is a graph of the same inductor stacked for mid-range with 1 ma DC,
everybody thinks that DC affects only the low end so that is why SE transformers are bigger, to make up for the bass, well that is true but the high end also takes a hit, there is little inductance from the core after 2 k hz, so what ever is left gets wiped out by the DC bias on the core,
