salomonander
- Joined
- Aug 28, 2011
- Messages
- 951
Hey Ian
i did come up with something yesterday. maybe you can give me some feedback?
i attached a drawing to make things easier to understand:
i use 3 dpdt relays per channel (L/R, group 1/2, group 3/4). by default (when not energized) they pull their bus feed resistors to ground.... so no signal goes anywhere. i also have a 1p3t position rotary switch (group selection switch) that allows to energize one of the relays at a time.
so the channel would be routed to one bus only, while all other bus feed resistors are grounded.
in order to achieve a mute i run all the relays power supply through one jfet which i can trigger via a logic signal. when the jfet is energized it cuts all power to the relays - full mute.
what do you say?
ps: the "group module" plan shows no actual relay connections. just how i want to energize them. the relay wiring is in the next plan.
what do you say?
