I placed a 12volt DC, 120mm pc cooling fan in my isolation box to prevent heat build-up and powered it using one of those computer 4pin molex power adaptors that supply both 12 and 5 volts. Problem was that the fan was running too fast that it made a vacuum sound that was too noisy. I decided to plug it in using the 5volt power instead and it quietened it to a satisfactory level.
Will this shorten the lifespan of the fan or damage the 12/5 volts molex power supply I use?
