Siegfried Meier
Hey guys,
I have a scenario here where I want to use the headphone out of our Dangerous Monitor ST to send out to the tracking floor, so I can control the headphone level. I have a headphone mixer out there, but let's ignore that for a sec since I want control in here (and also, the Dangerous sounds way better).
It's around 70-80' of cabling, so simply running the signal out there on one of the balanced lines is riddled with hum and buzz by the time it gets there - it sounds great, but noisy when idle. Is there a device that I'm not aware of that will keep my line balanced all the way out there, and then just turn it into a regular stereo / headphone line that last couple of feet? I tried using a radial DI in reverse, level was too quiet. I was thinking of some sort of other balancing transformer or electronically balanced device, but that would make it mono really - unless I run it out in 2 separate balanced lines I guess. Just wondering if there's a ready made solution for this out there.
Sig
Sig
