S52 - Small Diaphragm Condenser Tube Microphone (5840, NT10/3)
I'm about to start building this mic and have a couple of questions:
1. Could I use a Primo EM-21 electret capsule for the project? If so, should I modify the build to suit it?
2. I have a generic Chinese PSU in the studio. Can I adjust it for 100V and 6V and use it with the mic? I intended to build the PSU on the board I bought from Milan, but I'm having trouble sourcing the toroid to use with it.
Craig
Hi Craig:
1) polarisation voltage of s52 mic is 50V, electret capsule doesnt need it. Im not sure if its possible join this tube circuit with electret capsule. Search for 'countryman' microphone circuit (- tube circuit with electret capsule and Jensen transformer).
2) yes you can use your psu. For transformer you can check m49 thread. There are some possibilities in BOM. In any case you can use mic with 120V on B+.
Best
M.
Just a reminder for those who may not know - 6205 is same tube with slightly different pin-out; sometimes easier to source than 5840.
Ive used the 5840/Ef732 , rock solid performer , only ever in cathode follower config though , wouldnt mind trying anode loaded version .
would be cool to know. I haven't built my mic yet, but have a TEAC mic with an EM21 and and old MXL that are ready for new guts.
I got similiar mics for dirt cheap. I want to test the differences betwen FET with P48V, Country Boy and S52 circuit.👍
    153.2 KB
I think it should work. Imho C2 is not needed. Check 'country boy' microphone schematic for inspiration too.
Thanks for feedback!👍
I am coming from the Country Boy circuit, a cathode follower with gridleak biasing.
The next step for me is to check the S52 circuit in this down stripped version. I call it the "skinny S52" circuit. AFAIK, this is the most basic tube head amp and thus the ideal canidate for a SDC mic with an electret capsule.
I am kind of uncertain about the grid biasing resistor. I am still a mic builder newbie and do not really know how to calculate them.
So my question, what effect does the value of the grid resistor have on distortion, noise, headroom and sound? How should I bias this for an electret capsule?
    29.3 KB
I built second S52 microphone. Thank you Piotr for great design and all tips. For this mic I used 10pF C0G feedback capacitor for lowering the output of microphone. In C1 position I choosed 3n3F cap and in C2 1nF capacitor. R3=100M and plate R6 resistor 200K. Im going to build another two microphones.
Stock BM80 (and also Pronomic) capsule sounds a little bit "harsch" compared to Maiku SDC capsule. Cant recommend Maiku SDC capsules more. Capsules from Banzai´s KM84 body kits fit on ISK BM80, Pronomic SCM-1 bodies...
Here some detailed photos:
Did you end up preferring the version 1 or version 2 schematic with this mic? I'm about to build mine.
Craig
has anyone compared these builds to the royer sdct? especially on drums / similar sources?
i'm wondering about how the topology of cathode follower vs anode loaded, how each topology deals with different types of sources like high transient / SPL sources like drums vs say violin.
(links are welcomed as well on this if discussed elsewhere.)
I found time and started building an S52 using Vamis Vac11 PCBs. I'm really excited to see how my matching 3U SDC capsules will perform in a direct comparison with this Tubemic circuit compared to other "non-tube" SDC mic kits like Schoeps Style, KM Style etc.
First is the power supply. This was easy, metal parts, PCB XLR connectors etc can be cheaply bought from Ali. A very good customer specific Torroid TX can be ordered online from Audiophonics in France. They have a very good online site to choose the perfect TX for your project, not really expensive, easy to adjust the core size, prim/sec windings, shieldings...
The second step is the microphone itself.
    2.6 MB
    2.2 MB
    1.8 MB
    1.9 MB
Second part - Microphone finished. I increased the two ripple caps C3 and C4 from the PSU Bom for B+ from 47uF to 100uF to get the Mic fully hum-free. I biased 2K5 Rk-> gives Va 45V and 1.5V Vk. This sounds absolute great with the 3U capsule. To achieve 100V B+ I set the Drop Resistor R3 to 4K5. Than I was able to set B+ between ~95-105V via the designated trimmer.
As for the Mic and the 3U SDC Capsule I use for for feedback cap a 5pF Mica. I also bought 1pF and 10pF Micas to test. The middle way sounds best to me. C6 was not necessary in any way.
The noise is nearly as low like from CM63 in original condition at first tests parallel compared with AML 73 500, same gain setting/stage and level via attenuation trimpor equalized. . Sooo smoooooth highs, more lowmids, very warm and gentle. Love it, its something really special to build this kind of tube mic.
Thankx to Milan/Jan form Vami and IN76d for their super great work and efforts they put into this project. I would motivate the guys here to build such a Tube SDC mIc. Cheeeers🍺
    2.4 MB
    2.7 MB
    2.3 MB
