SA-134 frequency Correction
ecaltd
Active member
... while waiting on parts for the other projects on the bench I decided to revisit this one. A few years back I had a pair of these that I went through and re-capped etc..
One of them I racked up on a 3U shelf with remote gain an Daven attenuators on the output. Time to do the same with this one, additionally I will install a Hammond 369AX power transformer to make it worldwide compatible.
Question to throw out there is : has anyone changed the C9 and C13 values to get a different curve out of the unit ? What do you think about a two or three way switch to change the caps depending on the source material being amplified. If I used shielded cable to a front panel switch would that few inches of wire make a difference or would it be better to mount it on the chassis ?
gb
I just went through mine and lowering Just the NFB resistor without the proper cap (C9) associated caused motor boating the final tube stage.
I too am about the rack up one of these and pan to just use the current gain pot and add a meter. The schematic doesn’t specify the buffer circuit for the meter or which meter model was used in the rack version. That being said I believe the Gates meters used in these were the big 3” Simpson models.
Doug would know.
Im curious how you did the out attenuator?
Doug would know.
I did the attenuator post output and meter post attenuator so you can get that lovely round distortion !
