Saturday Night Gear Porn
Bryson
Santa Barbara/Woodland Hills
The Vactrols in the E_L_O_P are Perkin Elmer VTL5c2 and the side chain is just an LM386.
chrissugar
Yeah, but it would be quicker to use ordinary strips/cable binders. Also easier to replace a wire later. I think that's a significant cost factor, since those puppies are handassembled by people who get a nice pay per hour.
LM386? Isn't that a small poweramp chip?
EDIT: Yes it is?!
http://cache.national.com/ds/LM/LM386.pdf
[quote author="kubi"]Strange, I can't see anything on the originals.
I guess my monitor declines.[/quote]
I guess my monitor is crappy also - the originals just look like black squares to me...
Best regards,
Mikkel C. Simonsen
Well, the originals do look dark to me, but perfectly detailed. Kubi's look like they've been converted to 2 bit resolution :? :shock: FYI, my computer is a @-computer (yes, that IS the name) laptop with a 15" screen, brandnew..
OH MAN...
Why do I have a feeling someone is going to stop by pissed off...
I mean how dare anyone pop the lid of a manley product :green:
I can not read the IC but I don't think it is a 386 might it be a 324 quad?
Kubi, you cloned the Manley pic :shock: :wink: :green: ..
Yeah, it's probably a quad opamp. Using a poweramp to drive a LED is a wee bit of overkill me thinks :?
a 386 could be used to drive an autotransformer like in the la3
Gus and Sismofyt, belive me it is an LM386.
In the e-l-o-p the signal that drives the LED [in fact two leds, antiparalell and the photoresistors are conected paralell too] in the VACTROL is audio signal ,not a rectified voltage like in normal compressors. The advantage is that it will behave like an LA2A because the time constants are dependent on the VACTROL. The only disadvantage is that you can't modify attack and release time constants. But this is the trick, you don't need this. The LA2A has only two knobs ans sounds great.
chrissugar
I don't quite understand you...?
I do the same in my opto comps, use the LDR's build-in attack/release times a' la LA2A. But I don't use a poweramp chip to drive my LED!
Sooo, why do they use an LM386? There's gotta be more to it than just current drive?
Gus, since they use Vactrols, they're just driving a LED. No need for step up trannies like in the LA2A or LA3A..
