Looks like my unit is a prototype. The rear panel has sirtckers as labels and there is a small "2" marketed into the corner. This unit doesn't have the Pull Bright or Pull Boost circuits, and there is a lot of Dry signal, even when set to fully Wet.Did you ever have any luck? I just got one. I like it a lot, but there's a lot of dry signal, even when the mix is set to Wet.
