Samuel Groner said:
I have the first-generation 896. I don't recall the exact part number, but (unless I'm mistaken) it was a standard bridge rectifier part similar to a MxS (M1S trough M8S).
If that is the case, I don't expect problems.
The design of the board is indeed from another company. Not something entirely wrong from the beginning--there are many others out there which seem to get around well that way, e.g. RME.
The difference is that RME actually answer customer queries and try to resolve problems .. compared with the MOTU policy of quoting for a replacement PCB which might not solve the problem.
Anyone with more info on the aging properties of Schottky leakage current?
As I said earlier, unacceptable leakage for protection diodes on mike inputs is still well within the leakage spec for Schottkys.
This is what THAT say on their latest 1510/12 datasheets.
"In revisions 0 and 1 of this data sheet, we recommended using Schottky diodes (1N5819 types) to protect the 1510/1512 inputs against overloads. Subsequently, we discovered that the leakage of these diodes could cause problems with DC at the 1510/1512 output. Upon further investigation, we believe that conventional rectifier diodes like 1N4004 provide adequate protection and do not introduce unacceptable leakage. Additionally, 1N4004 diodes are much cheaper and more readily available than the Schottky types."
The small number of Travelers I've opened up, Mk2s & 3s, all show signs that the diodes have been swapped recently, including the 'new' replacement PCB on my Mk2.
My first Mk2 had 3 channels go noisy within 3 mths. The replacement lasted 12 mths then 1 channel went noisy. I looked into this cos I didn't want to lose it for another 3 mths. Replacing the
SK12b 52 diodes on the offending channel with 1n4004s cured the problem. (
touch wood)
I have not heard of problems with Mk1 Travelers.
It is likely that if your Mk2/3 is quiet after more than 12 mths, it will be OK but not guaranteed. In fact all Mk2 owners I know personally have had this bad noise problem. Above -20dBFS
I wouldn't replace the Schottky's on a new Traveler, just those on a noisy channel .. but then again, I don't make a living out of its use.
