Disclaimer - Modify your own gear at your own risk. General terms - The bridging transformer completely replaces the opamp output amplifier circuit. You need one bridging transformer for each DAC output. That's it. The bridging transformer is doing the job of an output transformer in this case. It is the output transformer. More specific terms - Open your converter box. Locate one of the DAC's (or codec's). Read the number off the top and go to the manufacturer's website and get the datasheet for that device. I believe the Aurora uses Cirrus converters but that's a guess. With the datasheet you can identify the DAC output pins on the DAC IC. Again, somewhat guessing, the aurora uses voltage output DAC's which are differential and not single-ended. So there are two output pins per DAC. Remember..... most of these DAC's are stereo devices so there are two channels coming out of that one IC. The output pins will be labelled something like Vout L+, Vout L-, Vout R+ and Vout R-. Open up your aurora and tell me what the DAC's are and I can pull that datasheet and tell you exactly which pins are the output pins. OK. Now..... Get your digital multimeter out and put it in resistance mode or continuity mode. You want to probe around (gently) to find the first resistor connected to each of those pins. It could be a capacitor too but I'm guessing it's a resistor. So you want to measure zero ohms (or 0.5 ohms with meter lead resistance) or continuity between one of those pins and this resistor/capacitor you're identifying. Do that for all four output pins (two channels, remember?) and write all that down. Draw a little schematic picture. OK..... When you have that, remove that resistor on both pins of one channel. The aurora is probably SMT in there so you can easily remove resistors or caps. Well, I can anyways. You can save those resistors to put them back in later if necessary. Replacement 1206 or 0805 SMT resistors are less than $0.10 each in cut-tape quantities at Digi-Key. So don't worry about destroying a resistor. OK. After you remove those two resistors, grab your multimeter again and re-confirm that each output pin from the DAC goes directly to this one SMT resistor pad. OK. I have used Jensen JT-11P-1 input transformers to do this. You can buy them for 60 to 70 dollars a pair used on the bay. Any decent 10k:10k input transformer will work but they will all sound a little different. Not hugely different but a little different. But the transformers connected to your DAC's will sound HUGELY different from the opamp circuit in there now. HUGE I say. Huge and better. Sick and huge and better. OK. So identify the leads (or pins) on your transformer. One side is the primary and the other side the secondary. If you have the Jensen's, go by their datasheet. Connect the + (or start) lead of the primary to the Vout + DAC pin but go to that resistor pad. You can solder the transformer lead directly to that resistor pad. Yes, this is a little delicate. But if yer in this far, ya' better be ready to keep going. Let me back up for a minute. Before you solder these wires, figure out how to mount the transformer inside the box, even temporarily if necessary. Hold it in place with sticky tape or velcro. Whatever you need to do to keep it from rolling around and shorting out to anything on the circuit board. Or do this on a table where the converter box and transformer can sit while you do this. The transformer can just sit on the flat top of it's can if the wires will reach all the way to the DAC IC. OK. So solder that first wire as described. Then solder the - (or finish) lead of the primary to the Vout - DAC pin. Now, solder an XLR connector or a 1/4" balanced connector to the secondary or output wires. For 1/4", Tx Out + goes to tip, Tx Out - goes to ring. And then on the Jensen trannie, there's a white wire and a black wire too. One of those is the core lead and the other is the shield lead. Both of those go to the sleeve on the 1/4" connector. And you may have to connect circuit COM (or ground) from the converter box to that same connection if you get a ground loop. You'll know if you have a ground loop. It's obvious.
That's it. The 10k transformer provides the correct load on the voltage output of the DAC. Most DAC's want to see a load of about 3k or 4k ohms. So 10k is higher than that and works great. Less than 3k or 4k would be too large a load and would load down the DAC and sound like shit or destroy the DAC itself. So a $35. dollar transformer ($70. if new) is replacing about $3. worth of IC's and SMT components (if that). You will never know how this sounds until you try it. I have done this mod several times on at least two completely different DAC boxes. It's awesome. But ya' gotta' be prepared to do this work without damaging anything inside yer box. I do this stuff for a living so it's second nature for me. I don't have any photos of this stuff handy or I would post them. DW.
