a soBer Newt
This is totally hairbrained but how would you go about designing a tape counter for a Scully 280? I am thinking an Arduino with a hall effect sensor on the capstan.
A sensor just on the capstan won't know where you are located on the tape if you rewind, fast forward, etc.This is totally hairbrained but how would you go about designing a tape counter for a Scully 280? I am thinking an Arduino with a hall effect sensor on the capstan.
[I just used the Nixies to see where I was] -- Maybe these days you could use the Nixie tubes connected to some GPS circuitry and the Nixies could display your location coordinates!!! Just a thought.....(HA!!! HA!!! HA!!!.....)I just used the Nixies to see where I was and manually toggled the transport with my fingers,
OH that's super cool, might need to get one for my 440 deck.About 20 years ago I designed and built a timer/counter for an Otari 7308 using an Atmel microcontroller which worked well and stopped on 0 too. I have recently designed a version of it to use on a Scully 280B. I have also just finished the pcbs and code for a 5 function autolocator that plugs into the timer/counter. There is a 3rd deck interface pcb that is machine specific that plugs into the remote socket under the deck to take control over Play, Fast Forward, Rewind, Record. and Stop. I was about to announce this product after I get my order of PCBs back this month. I need to find out how many Otari 7308 and Scully 280B owners are interested in this invention. I'm planning to make an interface for Ampex 440s, and 350s too.
[About 20 years ago I designed and built a timer/counter for an Otari 7308 and I have recently designed a version of it to use on a Scully 280B. I have also just finished the pcbs] -- While it sounds as though you probably have everything about your "Timer/Counter Design/Invention" totally under control, should you -- might -- need any mechanical design and/or "Electronics Packaging" assistance of your product, feel free to contact me, OK??? My type of background is with the combined "Mechanical Design/PCB Design" of electronic equipment. A "Design Portfolio" is available upon request. My working on projects like yours "scratches an itch" that I have for designing "Pro-Audio" gear whenever I can. As you also probably well know.....it's just friggin' fun!!!About 20 years ago I designed and built a timer/counter for an Otari 7308 and I have recently designed a version of it to use on a Scully 280B. I have also just finished the pcbs.
[At this point I'm handling the Timer Counter and Autolocator myself] -- That's fine. I was merely introducing myself and letting you know that additional assistance is available, if needed. That's all.Hi MidnightArrakis,
At this point I'm handling the Timer Counter and Autolocator myself but you seem to have some impressive talents. If I run into some snags I'll keep you in mind. Each machine model is a little different, requiring some modifications to my code and deck interface, but I've made this thing fairly universal as much as possible. I know how to check my PCBs for manufacturing problems so that's not a concern at this point. Depending on the amount and type of interest I get on this site, I'll be deciding if I want to produce a finished product for sale, or supply users with my pcbs, programmed microcontrollers and a parts kit. that they can put together themselves.
I made my first one a long time ago because it drove me crazy running analog tape and not knowing where I was on the reel. I still love and use analog tape. I think it sounds great. If folks have old Otaris, Scullys, and Ampexes I think you might be interested in one of these. What other good decks are people using that don't have timer counters on them?
