Selmer 'Scintillation' Reverb
Walrus
London, UK
Would anbody perchance to have a schematic for a Selmer Scintillation reverb unit?
I know it is very simple (it only has 4 transistors in it!), but it would save me from taking it all apart and tracing the circuit myself.  ;)
The unit always has the dry signal present, then mixes in the wet reverb. The owner wants it wet only.....
Sorry, I can't help with the schematic.  But I would recommend that you take it apart and draw the circuit.  Every time I have done this I learned more about the piece than if I just read the schematic.  A 4 transistor circuit won't take more than half an hour and you'll feel good having done it!
Yes, I know. I was just being lazy. Also the owner doesn't want to spend too much sorting this out.
I traced it out and found where the wet/dry mixing happens and cut the dry signal path.
I'll post the schematic in the tech docs once I've drawn it neatly.
Effectively, yes. On the board is a long wire link after R6, so I just cut it in the middle. Makes for an easy fix in the future!  ;)
