Snatched this one off eBay for cheap. My hopes were i would be able to use it with DIY RF Condenser Microphone RF microphone designed by @rogs .
Sadly the capsule measures just20pf (50pf, i measured at wrong terminals, diaphragm is grounded) which makes it unsuitable for that circuit.
Just to test it, and see if there's any life in it I put it in my lowest pol. voltage mic with just 15v applied to the capsule. Lo and behold it worked! Next thing i put it on my testing mic body made out of CM60 with 60v pol. voltage, and the capsule doesn't complain at all! The fet might though as the capsule puts out insane amount of output. Which was expected.
As the Sennheiser document on MKH series design explains, the capsule is underdamped, and has a bell shaped frequency response which gets corrected electronically, with inverse eq curve.
Since it has so high output the noise performance with 60v is remarkable. But as it pushes the fet really hard THD isn't.
Rear rejection in the midrange is insane!
Here's the uncompensated frequency response of the capsule.
Red is 0°, green is 180°, blue is just for reference - 0° of Neumann's k105 in the same body so you can see how much more output Sennheiser has. Naturally when inverse curve EQ is applied it affects both 0° and 180° response.
I'll have to think about how I'm going to use it. Probably dual out mic, with variable polarization voltage to control the sensitivity.
I don't think i will be taking this apart, since I doubt I would be able to put it back together. Once compensated for FR it sounds killer! Here are some pics.
