rogs
I've started to try out a couple of transformers using Aliexpress formers and 0.1mm wire.... (c.38 AWG )@rogs
Update. Today i received the right gauge wire, just like in Spectrum ones. I got best results with 2X13 turns on primary, and 5 turns on secondary. This got me inductor range of 5uH to 15uH. It was extremely easy to dial in the inductors and i got even better snr with this one compared to previous DIY coil.
The 1st was a direct copy of the Spectrum coil, and turned out to be very similar..... Those formers seem to be almost identical
to the Spectrum ones.....
I tried out 2 x 12 for a tapped secondary, and 6 turns for a primary (to try and create a slighlty higher input impedance primary, to allow for better matching to the oscillator output.
I can only really do comparisons with the actual Spectrum coils, but first tests suggested a 'central slug' inductance of around 11uH -- which was a little bit higher than I was expecting from just a couple of extra turns?....
Now we have the options to vary both primary and secondary turns, a whole new world of 'optimisation' opens up ...... Certainly when using capsules with smaller capacitiances for example...
It may also allow more experiments with 8Mhz oscillators...... In theory, that type of former should have it's highest 'Q' settings at around 7 or 8MHz.
With the right conditions and a 'following wind'
This new option to create virtually a whole selection of different inductors - with various turns ratios and inductor values - may open up options for even better results?......
