Setting the G1176 question
Val_r
Naples, Italy.
I'm a little bit confused on how to set the +4dBu output.
I know that when the meter needle in on the 0, the output should be +4dBm, and so 1.228 volts, but which volts?
RMS volts (Vrms)
peak volts (Vp), or
peak to peak volts (Vp-p)?
Can anyone clarify?
Val
:roll:
Rms.
Audio level is always measured in RMS - even on quasi-RMS, internally peak reading voltmeters (unless it clearly states "peak", as in headroom and overload levels). But on quasi-rms meters, RMS is valid only for close-to-sine waveforms.
Jakob E.
