kkrafs
If you have a ring power transformer (power supply) what would
you recommend to be the best way to screen off the magnetic flux
from other sensitive cirquits inside the box?
Is it possible to completely shield the flux off?
With a stel plate, aluminium, or perhaps
wrap in the transformer in bismuth sheets?
The box is made of steel or aluminium and im aware
that this can cause magnetic flux problems to.
Perhaps i should go plastic with the box wich
then put other problems in to day light!
kkrafs
kkrafs
