[quote author="xvlk"]but to separate current (Schottki) and termical (Johnson) noise
is somewhat old-fashioned.
See:
Schalpeshkar,Debrueck,Mead: White Noise in MOS Transistors and Resistors, IEEE Circuits and Devices, November, pp. 23-29.
xvlk[/quote]
November when??
And when did separating thermal and shot noise become old-fashioned?? Is Oliver now hopelessly out of date?? EDIT: Ah, found it. Would help if you had spelled the lead author's name correctly:
http://www.ini.unizh.ch/~tobi/anaprose/noise/noise.pdf
Second EDIT: It's a very interesting paper, and I thank you for the information.
However, I find it downright shocking that Oliver is not even referenced---particularly when the paper opens with the statement, clearly intended to be provocative and revelatory: "Shot noise and thermal noise have long been considered the results of two distinct mechanisms, but they aren't."
Alas, all too typical of the Caltech folk, where Not Invented Here is practically tattooed on foreheads :razz:
Where were the referees? Sloppy sloppy.
