siemens C4 desk
Thanks  ;D
I only have input strips so the rest is of no use to me.
Pinouts is probably the first thing I need.
Schematics of the preamp would be cool too.
Hi André, yes the audioworld is getting smaller and smaller , so we´ll meet
sure again here.!!!
hello la-2a, here´s another man from the small audioworld with a siemens c4 desk! i also need some schematics, espescially pinouts. can you help me out with some scans? cheers
Hi , you guys,  you should know I got 2 Original books.!! Together about  6KG weight. Schematics EACH PIECE big like a table. ;) So I  will pin it on the wall and make very high resolution Photographs from needed parts but please you can understand it would take me too much time to scan all the schemos. The Pinout of the channel and some zooms I will post here very soon.
cheers
Hi guys, I some of you I just E-Mailed  some C4 Input module stuff.
Here some pinouts
cheers
    270.4 KB
It is the E6 Module. The difference is the Voltage controled Fader on E6.
cheers
    291.6 KB
Hello guys, A friend over at gearslutz pointed me this way.  I have a 12 channel C4 on it's way.
It's claimed to be in good working condition and appears very clean.
I'm seeking a tech in the Philadelphia area to have a once over look and will almost certainly need to delve into recapping.
Whether I can tackle that on my own or not remains to be assessed,
ANY info or insights / or ^ info on the documents mentioned above that were sent to the email acct. are very MUCH appreciated.
