Hi all,
Thanks for such great info on this forum - it gave me the courage to purchase a Siemens W295B knowing I had to solder up a Tuchel and possibly do a recap at some stage. Previous to this I’d done plenty of residential wiring but had never actually soldered anything. . . didn’t even know what a capacitor was!
Anyway – made a bit of a hack of the solder job as I used a bigger (thicker gauge) wire than needed but I managed to get everything put together according to spec. Put a multimeter on it and it’s got current going the right places. Also using 24 V 1 Amp filtered power.
Problem is it sounds someone’s talking through an electric tin can. Opening it up I was surprised to find TWO original orange GSF capacitors (photo attached) whereas the Kubarth schematic (and other pics on the internet) show only one. I've attached a picture of my W295 with 2 orange caps. As I'm limited to one attachment per post I'll post a comparison W295 immediately following this one showing the single orange cap.
So, before I get adventurous and pull out the capacitors to test them somehow (my cheap multimeter doesn’t test capacitance) my questions are these:
1) Should I resolder the tuchel with smaller/correct gauge wire, i.e could that be the cause of such a problem as I described?
2) Why would my unit have two capacitors instead of one as per the schematic?
3) Assuming tuchel is not the problem and I need (or want) to replace the existing caps, can someone recommend a suitable replacement? These GSF ones are labeled 100/35 which I understand to mean 100 Microfarad and 35volt respectively – though I’m not sure where to go about getting a replacement that will do the best job for this application.
Thanks for your help. This board is awesome.
