Simple crossover repair - matching capacitors
Canada
My project is about as simple as could be: I'm repairing a crossover in speaker with no high frequency response. The crossover is two caps and a transformer on a PCB. One of the capacitors has failed open, and I'm going to replace it.
What I'm wondering is how strictly I need to match the capacitor, both in terms of electrical specs, and also in terms of chemistry and brand.
Here's a photo:
The dead cap is the one that is lifted with the specs visible. On that basis, this is what I can tell from the original:
  • 330µF
  • 85°C
  • 100V
  • NP?
  • Electrolytic???
  • Nihtin ??? Brand?
Knowing that, this is what I think I should be looking for:
  • 330µF (exact value)
  • ≥ 85°C (at least)
  • ≥ 100V (at least)
  • NP? (not relevant?)
  • Electrolytic??? (replace with electrolytic)
  • Nihtin ??? Brand? (brand not relevant)
Can anyone confirm my assumptions about specs here? Are there any specs missing that I should be considering?
Yes, however the typical tolerance is +/-20% on these old caps.
If you buy from a specialized shop, they have a choice of tolerance, from +/- 10% to +/-2%.
  • ≥ 85°C (at least)
Actually I would prefer 105°C, but it seems the most common are 85.
  • ≥ 100V (at least)
Not necessarily. It depends very much on the expected signal level.
For a 100W speaker, the peak voltage is 40V.
That's what you need to check.
Typical x-over caps are rated for DC and AC, with the AC rating bout 40% of the DC rating.
I'd rather have a good quality 63V cap than a poor 100V.
Extremely important and necessary, since the loudspeaker signal is AC.
Actually, a film capacitor would be a better choice, but for 330uF, it would be huge and expensive and you would need to replace it on the other speaker (which I recommend in any case if you want decent stereo pairing).
Note that most of the commonly available caps are axial so you would have to adapt the wiring.
Yes, it's the brand. Irrelevant.
Thanks for flagging the NP for me. I missed the importance of that.
I'd rather avoid re-capping all the speakers if possible. This is a centre channel speaker from a 5.1 set, so it's already a slightly different design (this crossover is driving two 3" "woofers" in series; the rest of the speakers only have one woofer). Given that this is mainly a learning project, I'd rather not duplicate the repair five more times.
Is there a good way to estimate the tolerance of the original cap? The only marking I didn't document is the number "2405" written on the opposite side.
Since you bring up quality, how can I identify good quality caps if not by the specs? I'd prefer to buy locally, so I was going to trust my local shop, but I don't think they have non-polarized caps, so I may have to chase something down on Mouser.
OK I get that. However, statistics show that when one type of caps fails, the others will also fail, not tomorrow, but one day, so you'd better be prepared.
No, but typically these cheap capacitors were 20%.
I think it's the mfg date code, likely 24th week of 2005.
Unfortunately, specs are often doctored by the mktg dept, so are not totally credible.
Mouser actually have suitable Panasonic and Nichicon. They all seem to be +/-20%.
You may want to try a specialized shop, where they handle Monacor, Mundorf, Jantzen or SCR.
They have up to 2% tolerance ($$)
Ok, thanks, I'll see what I can get from Mouser. I don't think this speaker is worthy of 2% parts, especially if the original can be assumed to be a 20% tolerance. For the moment, I'll just be happy if I can fix it and learn a bit about capacitors and filters in the process.
Taking that advice, would this be a good choice? https://www.digikey.ca/en/products/detail/nichicon/UEP1J331MHD/2597840
I'm having trouble finding parts rated 100V on non-specialty sites.
I also found this: Jantzen Electrolytic Capacitor 330.00µF 100VDC M.D.L. Series Non-Polar "Discontinued"
But Jantzen's website gives me more than a whiff of audiophile technobabble that gives me snake-oil vibes.
