I'm having trouble to wrap my mind around this...
As there's only one planet Earth where you can stick a grounding rod in the soil... they will always meet at some point.
(I've been working on a offshore project, and there's two huge copper busbars, one labeled green yellow, mains ground and one labeled, black yellow, instrumentation ground... so first thing I did was take my multimeter to the busbars to find there was 0 Ohms between them ..... aaaargh .... just shoot me !)
But appearantly it is important where they meet...
To check if I see this right;
AC ground from the IEC socket connects to chassis (all metal parts) and to the PSU after rectification (I usually connect this point to my last capacitor negative pole on the PSU output)...
Now there's also an audio circuit, it has input and output transformers, so this audio circuit is actually 'floating' between the two transformers and there's no physical connection to the outside.
So this part connects to the signal ground comming from the XLR input ?
Is there a point in the unit where these two meet ? ...they will shurely meet somewhere outside the unit as there is only one planet Earth...
edit;
Wouldn't it be best practice to leave the floating part floating ?
Does there really need to be a reference to ground ?
I also noticed on most really really old gear, there's no ground connection at all ?
(my interest is with this situation as I am planning to build this) ..So with this transformer balanced circuit it sort of makes sense to me.
But if we have a transformerless single ended design mains ground and signal ground are allready connected at the input, so it will no longer matter what you connect where ?
Ian, thanks for the document, but I'm still not shure if I really get this.
I've never encountered any hum problems in my builds so I guess I'm doing it right...
Aaaargh... just shoot me !
edit;
