Ah, finally a reply. :grin:
Its kind of a simple design, think of it as a baxandall/james without any control over mid freq.
The output sits at about -6db (dependant on source resistance) with the pot(s) centered (assuming linear pots). If the load is high enough Z, the response is flat.
Turning the pot to max treble, min bass the output will be about -30db @ 20hz,
and the oposit will do the same @ 20khz.
The only downside is that there is no real control over mid freq. as in standard tonecontrols where you can cut bass and treble to achive a mid "boost" and vice-versa.
This is not a problem for me as i use this in a guitar amp where i think that mid should be left alone.
Example:
R1, R2: Dual gang pot Linear 2x470k
R3: 470k Edit: make that 330K
C1: 500pf
