CJ
today we are going to build a pickup for an acoustic guitar,
we are going to use parts from an old Fender Telecaster neck position pickup that was available after a humbucker took it's place,
i had put tape around this pickup to protect the wires, we i removed the tape to do a neater tape job, a bunch of small wires became attached to the adhesive and snapped like a dry twig in a stiff desert wind, :-[
thats ok, we have a winder and some hair wire laying around in #48, #49 and #52,
i will not Even attempt to use the #52 hair wire because i want to keep what little hair i have left,
we took notes on the start and finish as related to the coax gnd and hot, the winding direction, the type of winding (machine vs random), and we scratched an X on the tops of the magnet pole pieces to keep them oriented the same way, you can also check by simply putting the magnets near each other, like poles repel, unlike attract,
here are some parts to look at>
