bcarso
[quote author="clintrubber"][quote author="mikep"][quote author="bcarso"]
What occurred a while back and I've never seen, but may well have been done: have a sample-hold for the needed correction voltage. Update at prolonged times of zero signal, unless another comparator detects something outside of a permissible window. If one uses an infinite-hold-time S/H (a/d to memory to d/a) you don't have to worry about hold capacitor droop.
Then one could truly say that the servo is out of the signal path most of the time.
[/quote]
precisely what I have been postulating for some time as well. has a digital servo been implemented in a commercial audio product yet?[/quote]
Not that I know of, but it's at least been patented:
http://www.pat2pdf.org/patents/pat6605990.pdf
(if this is what you mean)
Regards,
Peter[/quote]
Not exactly what I describe, although the Philips patent is interesting in the technique of using digital integration in a counter.
What I'm talking about is having a more-or-less conventional analog-domain servo, then using a zero-droop sample-hold for the servo-determined correction variable (voltage or current). The Philips invention (based on a quick glance-over) is integrating and correcting all the time.
[/quote]
Regards,
Peter[/quote]
