>>>mean that they sound better than other 4558's?
I think they are all the same. ST Micro, Fairchild, and TI are the only other manufacturers of that part # currently. I think if I got to choose, I would go for TI, personally, but then again I would go for 5532 instead.
>>>I think the jumpers switch the unit between...
Good one! :thumb:
>>>...who wants the best pre's for £100.00.
And that is what you got. If you want better, you'll have to invest more money or time or a combination of both. :green:
>>>try desoldering and see what happens 1 at a time
Good plan, but I suggest using machine pin sockets as the circuit board will probably not survive a lot of soldering/desoldering.
>>>Oh dear I might have got hooked.
hehehe! Too bad!
You can try all sorts of things in there. You might like two channels with tants, two with electros, two with electros bypassed with films, and two with film caps (good luck on that last one.)
HTH!
Charlie
