SMD workstation question
capacitorless
Denver, Colorado
I'm older and while I thankfully don't have anything like Parkinson's, sometimes I don't have the super steady hands that I had when I was younger. Especially after coffee. So, I'm looking for ways to assist SMD work. One, of course, is a good magnification setup.
Is there some kind of device that would translate larger movements into finer ones, and/or support SMD devices while being placed on a circuit board?
It could be as simple as a squeeze-to-release tweezer mounted on a flexible wand, or more elaborate like a robotic device thingy. I just haven't run across such a thing myself, so far. I've got a PanaVise, just looking for something more precise and more reliable than my hand.
What you are thinking of is a pantograph placement mechanism. I can't say that I've ever seen or heard of one, but that's what it would be called. Might be easier to program up an X-Y robot arm.
One good thing about SMD is that the parts are so small that surface tension will often self-align components onto the pads after heating them up hot enough to melt the solder, when placed roughly in the ball park.
Since I'm brand new to SMD (both building new boards and doing rework) that's great to know.
I should practice some and revisit this idea afterwards. It might simply be more trouble than it's worth.
I used to hand solder parts as small as 005010 (5/1000" x 10/1000"). It required a 40x power zoomable microscope, high precision tweezers ($75 & up) and abstaining from coffee.
Hint: Buy more parts than you need; if the part slips from your tweezers you'll never see it again. These were about the size of table salt grains.
I never saw or messed with parts that small. FWIW for high performance audio circuits extremely small SMD parts can exhibit compromises.
Yup, even parts 10x that do not often come back if dropped.
