Svart
What are people using for critical film capacitors in audio band EQ circuits and such
PPS caps? I have some but never tried them out. I don't think they come in smd though.
jdbakker said:I used a stainless steel stencil to apply solder paste, then put all the parts down with tweezers. After that I reflowed the solder on a hot plate. The process went reasonably well, and I'm working on streamlining it as I need to build a dozen more. There are over 60 line items (ie unique part/value combos) on both boards; sorting through these takes a considerable fraction of the build time.
+1
I recall when we first started using SMT years ago in mixers and the immediate benefit to mic preamp layouts due to reduced loop area for sensitive circuits. You could just about fit the mic pramp under the input XLR. Back in the early days it was difficult to get some of the low noise transistors in SMT packages, because they were relatively large die for small signal transistors, but it was all worked out.
I don't have as warm and fuzzy feeling for SMT film caps, but maybe that has improved too... I had one bad experience with a small CM where the reflow temps affected the film caps, I tried to use. Ended up changing to a more robust part.
This is not new, the old polystyrene caps were not factory friendly for through hole.
Rochey said:"amazing" accuracy isn't needed when soldering on the skillet![]()
