eddie_ruff_
Active member
- Joined
- Dec 19, 2016
- Messages
- 39
I'm trying to recreate the Studer MicValve Switch Mode Power Supply. It features 24VDC input and several different outputs (+-15VDC, elevated DC heaters, -300VDC, etc). The two main ICs are L4962 and L4960 (obsolete but still able to purchase for now).
I've built and tested the attached schematic and everything works except the +-15VDC rail. I've narrowed down the issue to L11. I initially saw this as a common mode choke, but I'm now thinking it's likely a 1:1 flyback transformer.
The service manual mentions that L11 is a 2*250uH storage inductor. But with 12 pins and a similar footprint as T7...I think it's acting more like a flyback transformer.
The issue I am having is a bit complex, when I first tested the PCB, I did so unloaded and I think I might have damaged the +15VDC rail. After I added a 10K resistor between +15 and ground, I was still getting a dead short through L11. So for some reason, I get DC on pin 7 of IC12 that is then shorted through L11 to ground. Shouldn't this be a PWM signal going into the primary like T7? Maybe my L4962 is fried since it isn't switching on the output...
Here are the two parts I've been thinking about using. I went with the second one for the PCB. Should I be looking for a 1:1 flyback instead?
CYSTF0805TL-251Y BC(Bao Cheng Elec) | C261394 - LCSC Electronics
CYSCM9085TL-162 BC(Bao Cheng Elec) | C261384 - LCSC Electronics
