Consul
... that a PCB can be too good.
I bought a microphone kit from MicrophoneParts.com, which includes a new capsule. The donor mic is an MXL V67G. So far, so good. It's a pretty high-quality kit with all of the hand-matching and selection done for you, and the PCBs are of extremely high quality, with through-plated holes.
Those are the problem.
I had accidentally "plugged" one of these holes with solder. Desoldering wick doesn't work. Solder suckers don't work. I tried working the lead of the resistor (thank goodness it was just a resistor and not something very heat sensitive like a transistor) through the hole with the iron on the solder, but that just resulted in metal fatigue breaking the lead right at the resistor. A few minutes and one vise later and I was able to solder a new lead onto it, although really, I could've grabbed another 100k out of the parts bin.
In the end, I ended up bodging the resistor in a "surface mount" style, connecting to the next part over with a solder bridge (it's supposed to be connected). And then I wrote them an email to tell them that they might want to consider using slightly lower quality PCBs in the future that can actually be desoldered with tools that hobbyists might actually have.
Sorry, I guess I'm just venting now.
