I measure 0.34mm.What diameter are the pins?
Thank you, this is the first real proof that these sockets exist at all. My Google research had yielded nothing. It will not be easy to find a source for this. (on my side of the big pond)These aren't in stock any longer at Phil's Good Gear, but were listed a year ago or so. It might be worth reaching out to them, to see if they have a source (or some more that they would part with):
https://reverb.com/item/46763069-cinch-subminiature-5840-tube-sockets
Sorry, that's not quite right. As I mentioned before, the 5840 comes in two versions.The 5840 was designed with soft wires for hard wiring into circuits. That was for reliability under high vibration and military use.
Completely unsuitable for a plug in socket.
Oh, you’re the guy!I bought a NOS lot of these on ebay years ago and built mics with socketed 5840 tubes. They worked great - makes it easy to check/swap 5840 tubes in a mic. Never had a problem operating the mics with them.
Watch for "subminiature tube sockets" on ebay or other places. I've never seen new manufactured versions, just NOS. There are a few with ridiculous prices on ebay now - not sure if they would still come up reasonably priced or not.
If you just need one I might be able to find one, I don't remember if I had any left
Welche Artikelnummer ist das bei Jan?Look at that, I found some for PCB and case mounting. Nice.
Source:
Frag Jan zuerst- Ask Jan first: Roehren und mehr
