G Greenie Well-known member Joined Jan 31, 2005 Messages 218 Location Norway Jan 8, 2006 #1 Hi... Does anyone know where to get a socket for a UTC A10 to be used in a LA2A clone? I have a Lundahl micpre there at the moment, but will change it to the A10, wich I have. Best from Greenie.
rafafredd Well-known member Joined Jun 3, 2004 Messages 2,409 Location Rio, Brazil Jan 8, 2006 #2 I don´t think it was meant to be socketed. It´s a solder LUG transformer. Solder the wires direct to the LUGs.
G Greenie Well-known member Joined Jan 31, 2005 Messages 218 Location Norway Jan 8, 2006 #3 Hi and thanks.. How do you attach it to the unit? Best from Greenie.
vibrolax Well-known member Joined Nov 21, 2004 Messages 66 Location Rochester, NY USA Jan 8, 2006 #4 There are 4-40 screws on each corner of the can, top and bottom. Jon
G Greenie Well-known member Joined Jan 31, 2005 Messages 218 Location Norway Jan 8, 2006 #5 Hi.. Nice info. I can see them now. Any knowledge on how the A10 works contra a Lundahl 1758 micpre? Greenie.
rafafredd Well-known member Joined Jun 3, 2004 Messages 2,409 Location Rio, Brazil Jan 8, 2006 #6 The A10 is one of the finest high ratio mic input transformers man ever made. Sight!
CJ Well-known member GDIY Supporter Joined Jun 3, 2004 Messages 15,736 Location California Jan 8, 2006 #7 here are A-10 and HA- 100 X templates in pdf: print and compare scale before drilling! http://vacuumbrain.com/The_Lab/TA/Templates/a10_template.pdf http://vacuumbrain.com/The_Lab/TA/Templates/ha-100x_template.pdf There are some close tolerances so you really have your work cut out for you. jpg:
R rmburrow Well-known member Joined Oct 8, 2013 Messages 234 Oct 11, 2019 #8 Links to templates are broken
rackmonkey Well-known member GDIY Supporter Joined Sep 20, 2016 Messages 969 Location Texas Oct 11, 2019 #9 CJ’s new site is https://vacuumbrain.uk/. On quick glance I didn’t see those templates there, but you might fish around more thoroughly.
