One of my chokes (not selling this one) had a problem with a broken lead wire, so that I will have to rewind one bobbin.
Just for reference, the V72 Chokes use 0.067 mm wire (I have a digital micrometer and I just measured it). Some of that will be the insulation, which is quite heat resistant.
Basically the same diameter as guitar pickup wire.
I removed 15.6 grams of copper from one of the three bobbins, so it will take a full 50 gram bobbin to wind one of these.
Total DC resistance is typically between around 11.2 KOhm
The laminations are one piece, and the middle tongue has to be bent slightly to remove them from the bobbin.
There are two spacers inserted between the bobbin and laminations which need to be removed.
Just thought somebody might like to know
