Sound Skulptor: Pre's, Compressors, Tape Simulator, Professionnal Audio Kits
Coming soon: Sound Skulptor EQ250 Stereo Parametric EQ for the 500 series.
More details in the first post.
Hi JPK,
When do you think these will be available?
Can these be customised for indented knobs for recall?
You mentioned inspired, what would be the differences between the original - do you have different curves, frequencies, etc. is the sound quality the-same, or yours is cleaner, low noise?
Thank you.
The EQ250 will be available in 2-3 weeks.
The potentiometers are typical 9mm pots which do exist with detents (11, 21, 41). But they are not standard and you will probably need to purchase a large number.
The main difference with the original is in the use of modern OPA134 and OPA2134 op-amps, allowing the removal of some coupling capacitors. So IMHO same or better sound quality.
