nrgrecording
[quote author="Xopek"]2 nrgrecording
About PSU
You have written a question, that a feed from SSl compressor will approach, but it gives out 15 volt. On your scheme of 17 volt. It is necessary to replace 7815 on 7817 (if such happen)?
And how on the account of a phantom feed in 48 volt?
In advance thanks for the answer.
P.S. Which transistors BC 550? bc550c or bc550b?[/quote]
Hi.
I used SSLtechs PSU (not the ssl compressor psu) which has +18/-18V/+48V. Works fine. You could use 7817 if you find them :wink:
I used the BC550 "C" transistors.
Regarding the pcbs... it would be cool to see finished units first to make sure that really everything is clear and correct. Although i don't think there is much interest. Who knows soundcraft consoles these days? :roll: :wink: But i really like the sound of the 2400.
Frank.
About PSU
Hi.
Frank.
