Admiral-dk
Not to ruin it for those with a Religious relationship with Inductors - but I see that most 'Pro Audio Gear' I service, has switched to using Gyrators instead for the last two decades (or more) ....
They are cheap, very reliable + it's very easy to adjust/construct to the value required
They are unaffected by Magnetic disturbances
You don't have to fight the Hysteresis Curve of the B-Field => much less distortion (as long as the supply voltage is high enough).
Only drawback - One end has to be 'connected to Ground'
Per
Per
