The unit works fine in echo mode.
In reverb mode it is ok if the feedback is set between 0 and 5.
After 5 it oscillates, the frequency is exactly 2kHz and 4kHz , 6kHz.
thanks Dave,
but this is not the case.
I've installed dip switches and with switch 3 closed (1), you bypass the ram's. DAC is connected to ADC.
Oscillation still occurs in the same situation.
