Speaker Impedance Converter
sysexguy
St-Sauveur, QC Canada
Got one of these.....feel like a bit of an idiot but....anyone know how these are to be wired? https://taweber.powweb.com/store/wzc50.jpg
I was expecting double the wires (ie a primary and a secondary).
Thanks in advance,
Andy
Hey, is that from Ted Weber? I know him from way back.
It's an autotransformer--a single-winding transformer. It's used to match a speaker to an amplifier. For example, you can use it to connect a 16-ohm speaker to an amplifier that only has an 8-ohm output tap. In that case, connect amplifier + output to the 8-ohm tap on the matcher, speaker + to the 16-ohm tap on the matcher, and connect the amplifier, speaker and matcher - (com) terminals together. Other combinations are handled in the same manner, using the appropriate taps.
Why do you need this? Are you using it on a tube amp or a solid state amp?
matching is a relative thing. some amps are missmatched if you use what you read on the web or in some books. For example there is a small 2 el84 amp that uses a 4K primary the same company used the same transfomer for a 4 el84 model.
I have used PA autotransformers on some solid state amps(under 5 watts) some chip amps go up in smoke others work when it works it sounds nice
go in 16 ohms come up 4 or 8 or go in 4 come out 8 or 16 etc....
