I went for this project a couple years ago, the SSL channel compressor I mean. I had only designed 1 sided PCB's in Illustrator so I had someone design the board for me in a real PCB program. I had 50 boards made. I never got it to work!
The problem is..... at least one of the dual pots (that was supposed to be board mounted) has one half reversed on the layout. There are no mounting holes on the board since it has 4 board mounted pots, they were to hold the board. Since they are layed out wrong that can't happen. However, the LED board which is attached and planned to be cut away for the metering, could be left attached and it's mounting holes used to mount the board, but then you'd need to come up with another LED board. The pots can be wired 2 (this is probably better anyway, cuz then you can use ANY size pots.
THE OFFER STANDS! anyone who agrees to troubleshoot the board, can have one for free. You then get it to work and report back to me/us. I would then sell off the remaining boards at a fair price, including the errata info. I do have the Gerber files and everything too, so someone could edit the files for the next production round too.
I have 3 front panels printed for an 8 channel unit in a Paia FracRack. I sure would love to complete that project!
PM me if you want to know more....
Mark
PS. this board is designed for the metal can AD536AJH and it's only about $8 from Digikey.
Mark
