TheBlackStuff
Member
- Joined
- Aug 5, 2011
- Messages
- 6
Hey Folks.
I'm getting to grips with the (really) basic care of an E series 4048 (40 E channels and 8 G channels) and what I believe to be a G series master section and G+ computer.
a few questions that have been burning my mind:
1 - There are switches on the desk (mostly EQ CH, split and DYN CH) that when NOT engaged can cause the signal on that channel to fart a bit. Aside gently pulling while wiggling them till a good contact is found, is the only other option to replace them all? (one heck of a job I assume, as I'm sure many of you will know from experience)
2 - After turning off the master section to sort out the mains in the machine room:
-the MONITORS CUT and the QUAD CUTS don't work on the RIGHT FRONT anymore...
-channels 1 and 2 seem to be bleeding through to the mix bus with everything muted,
Are these 2 problems linked? They certainly occurred at the same time...
What other info would one need, to have a stab at what components have gone?
3 - How do I lift a channel for the first time? I have reasonably good DIY/soldering skills and I don't think I'm an idiot but what do i definately need to do before pulling one of these things out to swap a dyn card and a few routing button cards...?
Thanks Folks!
PS. A big thankyou to everyone on these forums who posts answers about SSL E / G stuff, especially Keith, from whose posts I've already learnt a lot.
Thanks Folks!
