midwayfair
I'm a little loath to open this up, but I think the device is actually behaving a little strangely.
What I'm looking at:
-Two Hairball Rev D boards, plus their transformers, pretty certain it's this version: https://www.hairballaudio.com/blog/resources/build-guides/building-the-power-supply
-Some modifications from me -- a bunch of extra ratios, using matched 1% resistors, and extended range on the attack and release knobs. However, the imbalance persists even with the compression bypassed (pull pots).
-I matched all the transistors at the time of building
-I matched the pots as best I could, measuring the resistances at four spots, and they're with some reasonable percentage (probably like 5%).
-Right now I've got the volume balanced, and the compression balanced when I turn it back on, with the outputs at identical spots, and the left channel at 5:00 and the right channel at 2:00. This feels like a pretty big discrepancy.
-My metering on my interface tells me it's an 8dB difference between the two channels at max. This feels like a LOT.
-I can't detect a sound difference between the two channels when I run a mono signal through them and I don't see anything funky on the metering on coming back in, so I'm pretty confident. I don't see any damage and my voltages appear to be correct.
I can live with this (hell, I have for years), but I'm actually a little mystified considering the effort I went through to match the two channels. And while I can't be absolutely certain, I actually think that the left channel must have lost some gain at some point. They've always been a little mismatched, but I don't remember them being this far off, I I mostly remember just needing a small adjustment. Unfortunately I've lost my notes from the last time I used it for its stereo purpose so I don't have the settings I was using before.
Is there a part that could have gone wrong that isn't obvious?
