CAVE EATEN. LOOKS WORN. INSIDE.
Do not panic. Stay calm. Enjoy your trip. Hydrate.
Do not panic. Everything is under control. You can trust us. You are safe.
Cave Eaten? Seriously ???
(actually quite funny)
OK, I concede my post is a "bit" over the top, but I was not at home with no time to research the matter, and as I wanted to dispel any rumors cameras provide 48v phantom voltage, I went bombastic. While my goal was to get HIS attention, it appears I got YOUR attention, instead!
Still, I think it is a useful observation, n'est ce pas? I do not believe mixing 48v phantom voltage with devices designed for 5v bias voltage is a good plan, for example his 48v LDC microphone may not work on 5v bias voltage, and I suspect pumping 48v into a 5v microphone is contraindicated. I also suspect mixing 48 v phantom voltage on an unbalanced circuit with a mic capsule designed for no more than, say, 10 v bias voltage, is a good plan. These devices all run on smoke, and if you let the smoke out, they usually quit working. Putting 48v phantom voltage on an electret capsule rated for less than 10v seems a bad idea. Or am I really that far off base ?!?!?
_____________
Sidebar -- I was visiting my blind friend, and used his phone with speech recognition software to send my message - he was demonstrating his new electronic glasses with little cameras and AI technology that can "see" objects and tell him what they are, like looking in the pantry and telling him he is looking at a can of peaches, or lima beans, and not drain cleaner - a rather useful set of distinctions, don't you agree?
____________
So yes, while I may have exaggerated the point, I hope I got the OP's attention - as I truly consider the distinction more important than you let on !!
