After a period of searching, I have some guesses about this module. According to the speculation, it is similar to the PV46 or OV60 (OV-OMV, haha!) produced by Neumann - they have the same input transformer (Haufe RK204), the same operational amplifier (OA10). But for the output transformer RÜP 114M, I did not find any information, I have sent an email to the documentation staff of pikatron, and look forward to the reply. Well, to sum up - this is a microphone amplifier module produced in 1930, maybe it changed its name (according to k brown) for selling in the United States. If anyone can provide further information, I will be very grateful.I would guess,, like the U47, this is a Neumann unit marketed in the US under the Telefunken mark.
Oh, I think you are right, I just saw the word “930” on the label, so I had this guess.Hmm - looks more like something from the 60s, rather than the 30s.
Ah, I think I understand. That was a confusing history. Speaking of which, I did not find a completely similar product, maybe it is customized or produced in small quantities? I don’t know.Back in semi-ancient history, a company called Gotham Audio had managed to "control" the import of Neumann products into the USA. Look up Gotham or it's ....mmmm.... to be polite... it's very cranky owner, Stephen Temmer.
Perhaps the reason for the dual markings?
Bri
rather 70iesHmm - looks more like something from the 60s, rather than the 30s.
Most likely, although the gain could also be controlled externally via the contact pinsLooks like there are spots for four output transformers, but no (external) gain adjustment - some sort of line / ditribution amp?
I'd rather think it's a 1 into 4 distribution amplifier. One can clearly see there are 4 different outputs (although two xfmrs have been cannibalized).Well, to sum up - this is a microphone amplifier module
+1I think you should trace the circuit, it's not too difficult since it's a single-layer PCB.
+1Be ready to replace all these orange caps.
It sure looks like SOMEONE did some poor quality butchery at those two positions on the card.Not necessarily cannibalised, it often happened that these cards were not fully loaded from the beginning because this option was not needed.
+1
+1
You're right, I overlooked that. But as I said, many were simply not fully equipped. In this case, however, they were clearly canibalised.It sure looks like SOMEONE did some poor quality butchery at those two positions on the card.
Bri
I understand "partially loaded" options! <g> Eons ago I did design and installs of analog broadcast TV systems and often "short loaded" cards would be shipped from the manufacturer as part of a project.You're right, I overlooked that. But as I said, many were simply not fully equipped. In this case, however, they were clearly canibalised.
