Oh, almost forgot, maybe the expert @
That would be rather unusual. I would not make it dependent on two retrofitted capacitors. The position in the circuit of the caps also plays a role. The two ERO tantals seem to be coupling capacitors for the input to block potential DC. Best, as said before, trace the circuit and you really know what's going on.Oh, according to @rock soderstrom's observation, the capacitor is 20v, maybe it needs 15v power supply? I do not understand.
Yes, Volker knows bestOh, almost forgot, maybe the expert @
[silent:arts]
can help find the original technical files.
OK, got it. According to the datasheet, the OA10 op amp is typically driven by 24V, so maybe my initial guess was right. The RK204 input transformer has a voltage ratio of 1:2, so I can easily rewire it as a mic amp.That would be rather unusual. I would not make it dependent on two retrofitted capacitors. The position in the circuit of the caps also plays a role. The two ERO tantals seem to be coupling capacitors for the input to block potential DC. Best, as said before, trace the circuit and you really know what's going on.
Why doesn't @ work?
@[silent:arts]
In 1930 the transistor had not yet been invented.....Well, to sum up - this is a microphone amplifier module produced in 1930, maybe it changed its name (according to k brown) for selling in the United States. If anyone can provide further information, I will be very grateful.
It works otherwise, but the [ prevents it from parsing the username, looks like.
agreed, 1 to 4 distro card, only (1 to 2 currently possible from the photo) telefunken has a model that does the same thing, this is the neumann version, they come up cheap enough its tempting to try and test them out. but havent yet.I'd rather think it's a 1 into 4 distribution amplifier. One can clearly see there are 4 different outputs (although two xfmrs have been cannibalized).
I don't see a gain control, so it may be a unity-gain thing.
Be ready to replace all these orange caps.
I think you should trace the circuit, it's not too difficult since it's a single-layer PCB.
[looks more like something from the 60s, rather than the 30s] -- Or.....more likely the 70's, as I can't imagine even the Germans were using PCB's with TO-92 transistors as far back as the 1930's, despite their advanced engineering technologies back then!!!Hmm - looks more like something from the 60s, rather than the 30s.
Not really, as said before, trace the circuit, that is not complex. One input circuit and four equal discrete drivers for the output transformers. Quickly done, you will learn a lot.I think it may be difficult to obtain further information.
and yes it will be positive 24V in that era.Not really, as said before, trace the circuit, that is not complex. One input circuit and four equal discrete drivers for the output transformers. Quickly done, you will learn a lot.
Then tinker a 24V PSU and you are in business.
I'm not sure the input stage has a good enough noise performance for that.Use the sound imprint made by this module and make gain in the DAW. It´s better and more comfortable and safer.
Best regards!
