AardvarkBry
Tinkerer who doesn’t know nearly enough to fiddle
I just picked up this old tube compressor for almost nothing. It looks like it's pretty well made, and I'm hoping I can use it to add some interesting color. I found an old data sheet, and schematic, and I'm puzzled by how this thing functions. It says it has an 80k ohm input, and it can be used to either drive a 500 ohm line by adding a 1k ohm/2 watt resistor in parallel, or drive as low as a 3 ohm speaker by adding a 10 ohm/2 watt resistor in parallel.
I have 3 questions:
1. If I wanted to add a 600:50k, 1:10 input transformer, would I still need the 1k ohm resistor to drive the 500 ohm line level recording purposes? And would that be the best choice for an input transformer?
2. If you're driving either a 3 ohm speaker, or a 500 ohm line, does this change the input impedance?
3. How difficult would it be to add an adjustable time constant switch?
I have 3 questions:
