samgraysound
Hey,
I've got a compressor on my bench with a problem I've never seen before.
It's a Compex F 760 compressor. The owner says that with certain settings and input and outputs it will show gain reduction with no signal and show signal on the mixer but no sound (he's thinking super-sonic oscillation).
It does not do this when there is nothing plugged but will if:
unterminated xlrs --> inputs, outputs --> unterminated xlr
unterminated xlrs --> inputs, outputs --> studer mixer
certain outboard gear (but not others) --> inputs, outputs --> studer mixer.
The stereo input and output gains must be pretty high as well. He also reports that it is worse when run through the patchbay then when the unit is out of the rack and plugged in directly.
I'm a bit bewildered. Seems like it could be sort of grounding issue? What do I even look for?
Sam
Sam
