Chinese mic with Schoeps circuit
D1 and D2 are usually zener diodes (mostly 6.2V)
C9 doesn't have a function, it would prevent any polarisation voltage.
I highly doubt if R13 is really 456 Ohm.
Zener diode D3 may introduce noise, even with an 22µF electrolytic capacitor in parallel with it.
Indeed. And D3 shouldn't have been there in the first place. That's why I proposed to connect it to the collectors of the output BJTs. OK, original Schoeps circuit has the zener also connected to the drain resistor directly, but that is a less noisy 6.2V zener, shunted by 220uF instead of just 22uF. In my opinion, this is a design flaw. Quickly simulated a slightly different Schoeps circuit that I had on my PC: moving the zener from the drain resistor node to the collectors node decreased output noise density at 1kHz from 30nV/sqrtHz to 20nV/sqrtHz...
Moving the zener to the collectors will inject some noise into the 150k resistors, but with sufficiently large coupling caps and low value drain and source resistors, will be strongly attenuated. And the noise will to a large extent appear as common mode noise on the outputs, so will largely be rejected by the mic preamp. Alternatively, take over the power supply scheme from the pimped Alice design, but forget about the useless 10nF and 100nF caps shunting the decoupling electrolytic capacitors. The multistage RC filtering will completely prevent zener noise from entering the audio path.
Jan
Stupid question but what is the function of R12 110 Ohms in series with R11, 1GOhm? Should there be a capacitor, etc hanging off the junction?
Yes, I saw that too! This resistor (if it is really there) has absolutely no function.
I didn't mention it because there is a possibility that it is used as a 'bridge' on the PCB.
But in that case they could also have used a piece of wire...
