bluespills
Active member
- Joined
- Nov 7, 2015
- Messages
- 26
Hello,
this is one of my first DIY projects (besides some kits where everything is pretty much done for you) so please bear with me.
I'm racking 2 mono input channels from the studer 089 (1.090.017) , and using the 089 dual line amp (1.091.035) for the output. I will order probably a silent arts kit for PSU.
I am posting here a diagram of how i planned to connect them, but please if you see a mistake or a better way of doing it, advice is very appreciated!
My plan was to use the reverb send as the output, so that would act as an output attenuator.
The output of the input module is unbalanced, and the input of the line amp is balanced, so i hope i connected these correctly.
Anyways,i thought i would post this before i start and hopefully avoid some mistakes.
cheers
Zack
cheers
Zack
