studer 169 two channels sound weird
lobit
Member
Ive had this mixer for a few years.. in the last month or so.. two of the channels develloped the exact same issue..  basically sounds a bit like a high frequency warble.. like the input is becoming frequency modulated.  i tried switching the position of the  bad modules around but no luck  tried to run the mixer on battery power  same problem.  when I cycle the power, there is a moment just as it powering up where the channels sound normal and then they get weird a second later.  thats what made me suspect power.
any ideas?
I tried swapping positions  good channel into bad channel..  its in the strips
