Studer 961 Mono Input Distortion
timtom
Berlin, Germany
I'm repairing/recapping a Studer 961 Mixing console. 7 out of 8 Channel are working fine. One Channel is distorting.
I think I narrowed down the source of the distortion.
When I follow the signal path the distortion shows up the output of IC 9. When I check the input pins 2/3 the signal is distortion free.
When I use the insert return the signal is clean as well.
I assume the fault is between IC 9 and and the insert return.
IC 9 also gets hot.
I switched IC 9 and 10 still distortion. I removed C55, then the output of IC 9 is clean.
Any Ideas?
Hi
No clear idea yet, maybe check that there is no mess with DO -option 2- setup ?
Like if -wire 12- feedback/loop signal from fader buffer output or the 33Ω in circuit, wile you have a standard setup with sym I/O insert ?
What does the output of IC9 look like if you plug an unwired balanced jack into the Insert In jack?
[Edit] Sorry said Out but meant In.
It is still disorting.
When I take the output of IC9, disconnect C55 and connect it to the Insert In I get a clean signal. It’s phase reversed and ~4db lower but clean.
Taking out IC 10 it still passes a very low and distorted signal to the fader.
Seem normal as unbal insert mod need gain change (R136/137) and polarity flip at IC11
Can you check or replace trim R39 (200Ω) ? I'm not that sure, but faulty trim may impact IC9 load, as IC10 cross-coupled behaviour ?
Make sure bantam plugs are clean, and try an external wire O/I loop to bypass the normalling, bad contact ca mess with the cross-coupled
Also you may try the -option 2- mod, to see what happen then for IC12 (fader buffer out) loaded with IC 10 ?
(no need to changes R136/137 for this test)
No more ideas yet...
Zam
Sounds like R39 is dirty and goes open circuit when moved, this mean the op-amp has no feedback so goes maximum gain!
If IC9 is getting hot, then it is either oscillating at very high frequency, or it has to low a load. I suspect something happened to the tracks when C55 was changed....
Distortion at the Direct Out and the Fader.
Leaving W12 out and R208 in sound is clear with the level loss.
Most likely, I will try to use some wire to check.
fine... this narrow the issue around the IC10 cross coupled circuit ?
You said you recap the desk,
-double check C63 and C64
-clean and check all connection around IC10 and the recapped lythic, solder blob lost / trace short
-change R39 which is suspect so far (use 2x100Ω if you don't have trim yet)
- I hade issue in the past with double sided pcb from 80' Studer equipment, it's easy to mess trace/pad and TH plating when desoldering, so check top and bottom trace continuity around C63/C64 pads
I don't know exactly as I did several things before testing. I bridged C64 to R123 and I bridged both sides of C 55.
I also had to bridge W17 as I did cut the trace.
Another possibility could be the bantam sockets as I heavily used them during testing.
The console was in bad cosmetic condition. Lots of breadcrumbs, hair, dust and dirt.
